pretty sure when you cover one port the tuning changes so much that the problem go's away.... if this box is a shared chamber dual port box once you cover 1 port the tuning would drop.... say you were at 35hz cover one and you get 25hz.... so it sounds like the problem is that 1 sub is unloading, down side is you get 1/2 the port area... if you can try to do 2x on the size of the port and only run one
How much power are you running? Where is your subsonic filter set? It will be hard to know what you have until you pull the sub to confirm it is not damaged.
Pioneer 80PRS
Well I feel pretty dumb.. Figured out the problem.. Now it pounds good... Pulled the sub and right away saw the jumper hanging down... Somehow the stripped wires at one end was completely cut off so it disconnected one coil and was only playing as a single coil sub.. Stripped the wire Again plugged it back in and she's back sounded real good.. Appreciate all the help guys I shoulda looked into it before u stated asking for help but I was in a rush Thanks again. Everyone
