308power Posted April 21, 2016 Report Posted April 21, 2016 Hello everyone. I have recently purchased my first SUV (2 door tahoe) and can finally install a system like I would like to. The largest set up I have had so far was 2 12 inch l7s in a cheap Qbomb due to car space, but this is no longer a problem. The largest dimensions I have to comfortably work with is 48 wide, 26 deep, and 22 high. For electrical I have big 3, a 160 amp alt and an xspower d3400, and for my amp I have an aq2200.2d. I am open to whatever direction subs and port have been shown to be the loudest direction in tahoes I like to listen to rap, edm, dubstep, decaf, but I do listen to the radio on occasion (20%ish?) of the time. Thinking of tuning around 32hz but I have heard this is low for the soundcubed street series: with this in mind, I chose these woofers in the 15" size as the best bang for buck kind of deal due to a 400$ woofer budget but this could be stretched slightly. I would be glad to receive any information on the topic: and I am open to other woofer suggestions from those with more experience in the area. Thank you in advance. -Pierce
ShadeTreeMechanic Posted April 21, 2016 Report Posted April 21, 2016 Welcome to SMD! I have a pair of HDS315s tuned to 34hz in 4 cubes each and they slam. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Joe X Posted April 21, 2016 Report Posted April 21, 2016 So here is a suggestion for a box, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 7", figure is just an assembly guide:
308power Posted April 21, 2016 Author Report Posted April 21, 2016 Thank you for the welcome . There seems to be a wealth of knowledge to be explored on these forums so I should be here a while. As I am able to slowly able to move to bigger builds, hopefully i can start to be able to help others. Joe X, you are the man! That design looks awesome, This may be a dumb question, but when centering the subwoofers location on the top of the box, Do I center it in the middle of the panel to look even from the outside, or do I center It after subtracting the 5 inches of port width from the back wall from the port extension so it is more "centered" inside? Or I may just be overthinking all of this, Thanks again guys
