Painting box port
dsw422
Hey guys.. getting ready to paint the port on a box I am making.. I wanted to use a rustoleum spray enamel as a finish color..
my question is , what primer should I use?
I was thinking of using kilz oil primer or rustoleum spray primer.. I won't be painting any end grain.
Thanks for your help.
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
You should be fine with the matching rustolium primer.
If you plan to use clear, make sure the paint will accept it, I know the STOPS RUST line of paint will orange peal really bad if you use clear.
rustoleum always worked for me. I use their primer a lot.
Nice box!
Thanks!
1994 Ford Bronco
Sony door speakers
Port turned out awesome!! I'll be sticking with rustoleum from now on!! Maybe not for an entire box, but definately for ports..
Now time for carpet
1994 Ford Bronco
Sony door speakers
Wow, awesome looking box, I agree with the others. Rustoluem has never failed me...... post more of the build...
Does this smell funny to you? Its your sister :roflmao:
Thanks.. I'm building box for a friend. Box will hold 2 lanzar optidrive 15s (I kno ?). Will be in the back of a crown vic.. I'll load some more pics in a little while
1994 Ford Bronco
Sony door speakers
Here's some more pics.. still have to carpet the sides of the box and touch up the paint..
1994 Ford Bronco
Sony door speakers
I dont see many carpet the same way I do.. props!
Food for thought, next time you paint the enclosure without the top on make sure you mask off the edges where you will be laying glue to secure the top so its not painted over.
Wood glue likes and needs to soak into the wood for a good bond (hence why glues with a longer open or working time typically hold better because they really get to soak into the wood).
When you paint those edges your preventing the glue to soak in and could possibly be a weak point.
Thanks.. and I actually sanded the edges where paint was that needed to be glue.. not for the reason u said (but now I know) but because those pieces were cut just under a tenth to tall.. need to invest in a good table saw to prevent that..
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 963 Guests (See full list)
