DC Sound Lab
Hu grounded straight to battery. 2 battery grounds underhood straight to frame.2 frame grounds in rear connected to 2 d3100s all amps grounded to batteries . 4 positve 4 negative into dc5K all 1/0 ofc shca. Grounds our all solid
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Can I check that outside of box at speaker bolts?
speaker lead may be grounding out on the basket when the spider moves.
Not sure if its an instant protect, or if its only when turned up. Didnt read the whole thread.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
OK will do when get out of work
It's instant protect
You can check resistance outide the box but if you get a bad reading you will still have to take the sub out to make sure no wires are making contact with each other inside. I would hope that wires are somehow touching inside instead of having a bad sub.
Praying it's not a bad sub
  • Like (+1 Rep) 2
Unhook sub wires from amp plug rcas in turn on if it doesn't protect then it's coming from bad sub shorted sub wire etc .. If it does protect its rca issue most likely
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1828 Guests (See full list)
