99Laydorado Posted May 2, 2016 Report Posted May 2, 2016 Whats up guys finally got enough funds to start on my build looking at doing 4 DC lvl 5 15s (either D2 or D1) on 2 DC 7.5K. My electrical plans ar at minimum 2 singer 370a and 4 Northstar S480 (217Ah) and 2 of their G31(102Ah) up front. Was curious on yalls thoughts if this would be worth while to run at .5 or should I just go ahead and run it at 1ohm. Its gonna be more of a daily system walled in the back of my 99 x cab silverado. Thats why Im only runnin the 2 amps instead of say 4 3.5K I only have the one door. Thanks for the input 1999 Chevy Silverado x cab Bagged on 22s Stupid loud system to come
Miguels Posted May 2, 2016 Report Posted May 2, 2016 in short NO! my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
99Laydorado Posted May 2, 2016 Author Report Posted May 2, 2016 I kinda figured as much I knew that elec wouldnt cut it at .5 thats why I said my minimum I can always make the electrical side stronger just wonder if there is any real perk to wiring down to .5 especially for a daily aimed build 1999 Chevy Silverado x cab Bagged on 22s Stupid loud system to come
yurvalentine Posted May 2, 2016 Report Posted May 2, 2016 If you don't feel 110% confident wiring down then don't do it. The gains are likely going to be pretty minimal anyway.
hdorre Posted May 2, 2016 Report Posted May 2, 2016 Lets say you have 2x rise, which isnt overly uncommon for ported setups.. If you wire to .5, without accounting for voltage drop, youd expect 15kwrms If you wire to 1, without accounting for voltage drop, youd expect 9kwrms so 1.6x the power wiring to one. This was all simply going off RMS ratings. Hell, Daniel Crews and other gained by using less amps wired lower. Daniel has 4 DC 9ks wired to 1 per. He was louder with 2 at .5 per. Again, not uncommon. If you have any concern for your fets, then obviously wire higher. Whether or not the risk it "worth" the gain, thats user dependent, and nobody can answer that for YOU. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Carnines Posted May 2, 2016 Report Posted May 2, 2016 If you want to have higher numbers with the risk of damaging equipment then go half ohm. I don't see the risk being really high with your electrical as long as you aren't super dumb with your equipment.
