Help Explain Please
I would like to know what (200 Amp Battery Relay Isolater Wiring Kit) that is.
here is a link http://ngvi.ebay.com/vi?ngvi&backtoid=...5SIkOq9uZNAM%3D
Is that an option rather than getting another alternator?
If i have 2 batteries (KINETIK HC2400 or Stinger SP1500D Power2) along with my main battery under the hood. (KINETIK HC1800)
And my system will be a 500w 4 channel, and 3200w xxv collossus hi fonics amp pushing 2 FI 15 BL subwoofers.
will i need a alternator as well? or will the batteries be sufficient? Or could i use that isolator wiring kit?
Just need some advising on electrical specifics.
I would keep all three batteries and get an alt In my car right now i have a 220 amp alternator and 1 optima yellow top upfront and 1 Kinetik HC2400 in the back. I am running 1 Hifonics XX Thor and it does fine. I also have done the Big 3 upgrade all my wiring is 0/1 kollous cable i would highly recommend getting a high output alternator you could do more damage to your factory alternator since it will be struggling to charger up all the batteries. Im not using an isolator for my system. Do you plan on using the system with the car off?
before I ever even looked at the link I knew it was stinger and that one is a bit high in price.
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=5297
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
I'm the one that actually sells that kit listed. I have it on ebay and on our site http://www.darvex.com It's just a simple and safe way to add a 2nd battery. If you have an alternator between 85 and 200 amps it's a good kit. Also, if you have two batteries that aren't matched it allows the charging system to charge each accordingly. If you need just the relay it's 44.50, if you need all the fuseholders, connectors, and wire I have it posted on the link you provided. Anyway, If you need a diagram and instructions with some explanations as to how and why this is a safe way to do this let me know.
That's really not high priced. The link you gave only have the solenoid but the link my man posted comes with wire, fuse holders, etc.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
That is a PAC200 relay with a Stinger sticker on it. You can get it for 35-40 bucks as long as you dont go to a car audio shop to get it (they charge as much as $99). I have purchased several items from darvex, he will shoot you straight and has ok pricing.
You don't need one unless you just want one. I have one on my truck but it is only because i had a couple laying around the shop that were not being used. It will isolate your batteries only when the ignition is off. When you start the vehicle it doesn't charge them separately, it just links the two together like you had them direct hardwired together.
I would just fuse the pos wire between the two batteries, one fuse within 18 inches of each battery for safety.
Yeah, PAC and Stinger buy these relays from the same US manufacture. It's the same thing. Hey, here's a little more info on why I like using the relay set up. The info below is copied directly off the tech section on Stinger's site.
First, no two batteries are exactly alike. Because of this, they will slowly discharge each other when connected together.
Installation of the SR200 will allow simultaneous charging, but will separate the batteries while the vehicle is not running.
Secondly, if there should be a battery failure while connected to the bank no discharge of the good batteries will take place.
This is because they will only be connected while the vehicle is charging (running).
Compaired with the cost of high quality batteries, the SR200 could be considered a very inexpensive insurance plan for your precious power supply.
Edited by darvex
  • Who's Online   0 Members, 0 Anonymous, 799 Guests (See full list)
