Clownrock95 Posted May 7, 2016 Report Posted May 7, 2016 I have been looking but I can't get a straight answer so ima ask here I'm changing plans (again) and I'm considering going from a 1200 watt sub stage to a 2400 watt substage bringing me close to 3k total watts My problem lies in what batteries I need as I have seen many recommendations/builds -may03lt has 2400 watts and runs 3 d3400s -according to Xs powers wattage gauge I need (if I'm reading it right) a d3400 and a ~d680 -on the same page as the wattage guide Nathan says one d1200 and two d3100 would be "least that for a 3k system" -according couple pages later Scotti says" I would recommend replacing your stock batt with the best fit option and running D3100 in the back near the amps." In response to a 4500 watt question So I hope y'all see my confusion and can help me out Extra info: Have a D3400 under the hood Will be getting a 240 amp alt (mechman) Have 1 run of 1/0 (sky high) Will be doing big 3 Thanks for any help
hdorre Posted May 7, 2016 Report Posted May 7, 2016 Wired to 1 or .5? If 1, your alt alone will hold high 13s+. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Clownrock95 Posted May 8, 2016 Author Report Posted May 8, 2016 Wired to 1 or .5? If 1, your alt alone will hold high 13s+. @1ohm Not that I doubt you but that contradicts everything I've seen Anyone elts want to weigh in?
d-nice88 Posted May 8, 2016 Report Posted May 8, 2016 Im running 3.5 k with 2 xs power d3400 in the trunk and 1 autocraft agm platinum batt under the hood. I could run full tilt and drop to 13.8 the lowest. I have a mechman 250 alt to.
Karkov Posted May 8, 2016 Report Posted May 8, 2016 I have been looking but I can't get a straight answer so ima ask here I'm changing plans (again) and I'm considering going from a 1200 watt sub stage to a 2400 watt substage bringing me close to 3k total watts My problem lies in what batteries I need as I have seen many recommendations/builds -may03lt has 2400 watts and runs 3 d3400s -according to Xs powers wattage gauge I need (if I'm reading it right) a d3400 and a ~d680 -on the same page as the wattage guide Nathan says one d1200 and two d3100 would be "least that for a 3k system" -according couple pages later Scotti says" I would recommend replacing your stock batt with the best fit option and running D3100 in the back near the amps." In response to a 4500 watt question So I hope y'all see my confusion and can help me out Extra info: Have a D3400 under the hood Will be getting a 240 amp alt (mechman) Have 1 run of 1/0 (sky high) Will be doing big 3 Thanks for any help With a D3400 already under hood, getting a 240 amp alt from Mechman, 1 run of 1/0 SHCA, and big 3 gonna be done for 2400 watts or even 3k with running the amp at 1 ohm I feel that you will be more than good man. I wouldn't hesitate to run that exactly as you say. Just always keep a close eye on voltage. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
