Walled Suburban
Starting to build a wall with 6 12" Rockford P2d412. 800watts each & 400rms.
What im working with is 48" width, 34" high & 22" deep. I have plenty of air space. I want to tune to about 32-34hz. Ideas on the port. It'll be 1 big chamber with bracing. How much port area should i use. Any ideas?
Port area is very important, don't go small with it. Create the largest you can make, and then with testing, shrink it until you achieve your desired results.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
With having a huge port area the longer the port will need to correct?
Whats the minimum amount of port area. The port will probably be rectangle. I can make it the full length of the box if needed. Also will serve as bracing
There is no "minimum", it is application dependent. So unfortunately I can't answer that question without knowing more information from you. The acceptable general rule of thumb is 12-16cuin per cuft per sub if using a slot port. 10-14 if using a aero port.
6 15" SSA Evils
18 XS Power D3400s
Generally for a given port tune, making the port bigger will mean that the port would have to be longer to keep the same tune. But the box volume plays into this too. The bigger the box the shorter the port has to be for a given port tune. This is one of the benefits of having a common chamber for multiple subs.
Pioneer 80PRS
Can someone check my calculations for me.
48"x34"x22" wood thickness .71
The woofer displacement each .17x6=.51
Port opening 48"x4"=192"
Length 15" tune 34hz
Using 2 common walls (L&R side)
Port is located down the middle of box. 3 woofers above and 3 below it. Port can serve as bracing being in the center of the box.
What amp are you going to be running?
A 4" x 48" port has a really high aspect ratio, you might want to consider a different port layout. Also if you box is 48" wide externally, your port can't be 48" wide. It would be 46.6"
Builds:
Just remeasured. I could do a port at the end of the enclosure 6"x32". Top to bottom. Any suggestions
That's how I'd probably do it. Should work well.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 850 Guests (See full list)
