cocoleveo7686 Posted May 14, 2016 Report Posted May 14, 2016 I am sorry for this stupid question as it has been a long time since I have set the gain using a DMM. Someone told me I had to turn LPF all the way up while trying to achieve the 70 AC voltage, is this true? Or do I set it to 80hz then set gains to my Target Voltage?
08tahoe Posted May 14, 2016 Report Posted May 14, 2016 I set gain with my dd-1 but yes, lpf all the way up and subsonic all the way down.
ShadeTreeMechanic Posted May 14, 2016 Report Posted May 14, 2016 With the head unit all the way up? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Bayuk89 Posted May 14, 2016 Report Posted May 14, 2016 With the head unit all the way up? With the HU at its max clean volume, which you would only find while using an o-scope or dd-1 which is what you would be better off using to set your gains... i think a decent quality hand held o-scope sells for $60 on amazon..... good investment so you dont have to guess whats clean and whats dirty.
