pintich Posted May 21, 2016 Report Posted May 21, 2016 Hey, I would love some help to make a box designe for my sub. My sub is a Ground Zero GZRW 12D2 http://www.ground-zero-audio.com/components/com_jshopping/files/demo_products/GZRW_12D2D4_OM_052015.pdf Running it on a Ground Zero Iridium GZIA 1.1000DX AMP so its 1000wRMS on 1 Ohm. The car is a Mercades w202 sedan/saloon. so its a trunk The space i have is 74cm in width. about 35cm in height and 60cm in deep. the music i lissen to is Decaf. And sometimes "radio music" but for the most part just Decaf Can you make it in centimeters and Liter.
pintich Posted May 31, 2016 Author Report Posted May 31, 2016 Ok seats fold down? No you cant fold them down :/ its all metal behind the seat
Joe X Posted June 1, 2016 Report Posted June 1, 2016 So here is a suggestion, you will need to open up the rear deck to give sound waves a better return path, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 6 cm, figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. NOTE: Uses 19 mm wood if you have different thickness let me know.
pintich Posted June 7, 2016 Author Report Posted June 7, 2016 So here is a suggestion, you will need to open up the rear deck to give sound waves a better return path, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 6 cm, figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. NOTE: Uses 18 mm wood if you have different thickness let me know. thanks alot!!! my wood is 1,9mm that we have here think i can take my saw and open upp a smal "box" in the "hatrack" or what its calld in english hahah
notorious97200 Posted June 8, 2016 Report Posted June 8, 2016 If you have a Mercedes "berline" you could build a 4th order bandpass box. You must have a ski hole from trunk to cabin : the port will fire through that hole. That way, you won't have trunk rattles, all the bass will go and play in the cabin, not in the trunk. Good luck. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
