Junior_209 Posted May 21, 2016 Report Posted May 21, 2016 So I purchased a singer alternator from a friend when I plugged it in my 04 tahoe it said battery not charging does anyone know why
reedal Posted May 21, 2016 Report Posted May 21, 2016 What vehicle did your friend have? Did you connect the stock alt charging cable to the charging post? Same with the alt plug harness? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
ChevyBoy95 Posted May 21, 2016 Report Posted May 21, 2016 Incorrect wiring somewhere on your end if it worked for him. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted May 21, 2016 Report Posted May 21, 2016 Can you post pictures of said alt, the harness on your 2004 tahoe, and what it looks like currently installed (since it is not working.) edit: If the alt isnt charging either the harness is wired wrong (needs ignition and sense wire), or you don't have a power cable from the stud to the battery, or the alt is bad. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Junior_209 Posted May 23, 2016 Author Report Posted May 23, 2016 It came off an 03 tahoe and I'll post a pic in a bit
