American Bass VFL-8D4
If someone could help me in a box design for 2 American Bass VFL-8D4 subs for a 1991 Honda Civic hatchback, the dimensions are 17 Depth,15 1/2 Height and 34 Width. I have two amps in my possession that I can use one is a Rockford Fosgate PBR 300x1 and/or a
Hifonics BE2100.1d amp. I listen to rap, hip-hop. If someone could help I would appreciate it.
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Thank you sir! I have one question if I wanted to put the subs on the top of the box, would anything have to change on the design ?
You can take the design he gave you, and just put it with sub up port up. I used to have that same exact car, dx? Thing gets loud easy.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Yes it was made same depth and height so that it can be used firing up or back, for subs up / port back the above needs to be changed a bit.
  • Who's Online   0 Members, 0 Anonymous, 10140 Guests (See full list)
