akuma4u Posted June 15, 2016 Author Report Share Posted June 15, 2016 I'm still confused how you are going to cross your mids over. bro my mids are crossed over by my 4 chan amp and/or head unit. Link to comment Share on other sites More sharing options...
SkarredSierra Posted June 15, 2016 Report Share Posted June 15, 2016 As long as the new tweet is 8 ohms you should b fine. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 15, 2016 Report Share Posted June 15, 2016 If your tweeters are hooked up to the same channel as your mids, then you are filtering the tweeter frequencies and the tweeters will be doing nothing once you put a crossover on them. Unless I am just missing how you are hooking all this together. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
akuma4u Posted June 15, 2016 Author Report Share Posted June 15, 2016 If your tweeters are hooked up to the same channel as your mids, then you are filtering the tweeter frequencies and the tweeters will be doing nothing once you put a crossover on them. Unless I am just missing how you are hooking all this together. yes the tweeters will be hooked up to the same channel as the mids with a 5000hz crossover in between the mid and the tweeters. so right now how i have it set up is like this 4chan amp is set to full range and the mids are connected to that amp. i want to connect a 5000hz crossover to the front two channel mids so that i can connect 2 tweeters to those crossovers. from what i understand, those crossovers will allow frequencies above 5000 to go to the tweeters BTW, on an unrelated note, are u the guy on youtube that did the 15 inch sub challenge? Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 15, 2016 Report Share Posted June 15, 2016 No that wasn't me. I'll get back to you later. I'm on mobile, too much to type! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
akuma4u Posted June 15, 2016 Author Report Share Posted June 15, 2016 No that wasn't me. I'll get back to you later. I'm on mobile, too much to type! k no problem thanks for the help. Link to comment Share on other sites More sharing options...
