1 SA12 V2 Box help needed !
Sub: 1 Sundown SA-12 D2 REV.3 750 rms (wired to 1ohm)
amp: Hifonics brx1100.d
I would like the height to be 15" (max) and width to be 28" (max). The depth can be whatever it needs to be in order to get the box tuned to sound great for most types of music mainly (rap, hiphop dancehall) and the box is going in a Camry, a simple box but one that will preform well will highly be appreciated, I'd like to avoid 45 degree cuts but can do them. THANK YOU
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 3940 Guests (See full list)
