'98 Ford Ranger Extended Cab Box Design
DLHgn
Idk about that, i foresee loading issues of your passenger side sub with that design.
That's what I was worried about
Yea just because that is a large, flat surface that close to the cone. have you considered using 1/2 inch all thread for bracing?
Idk what that is.
Idk what that is.
http://www.homedepot.com/p/Simpson-Strong-Tie-5-8-in-x-36-in-Zinc-Plated-All-Thread-Rod-ATR5-8X36ZP/205330040
Just drill holes in the sides of the box you want to brace, slide the rods through, put some nuts and washers on, and crank them down. It's just as strong as wood bracing and takes up a lot less volume.
Idk what that is.
How would it work if the back panel is against the back wall of the cab? And same with the bottom?
Idk what that is.
You have a point, maybe cut a hole in the plastic and carpet where the nuts would sit? After you cut the excess off they should only stick out 3/8" or so.
Idk what that is.
Also, the front face is at an angle. What if I just do top and bottom as the bar and leave the front to back as the wood?
Idk what that is.
That should work, as long as it gets rid of that flat surface behind that sub you should be good.
So like this?
PtMTY9W.png?1
wqh2haX.png?1
  • Who's Online   0 Members, 0 Anonymous, 9600 Guests (See full list)
