DLHgn Posted June 26, 2016 Report Posted June 26, 2016 I received dimensions from a guy who has a Ford Ranger Extended Cab so I went ahead and used those dimensions to create this design. Specs:Drivers: 2 IS15v3's Power: ~2400w RMS @ .5 ohmNet Volume: 5.65 ft^3Port Tuning: ~31HzPort Area: 89.25 in^2 (5" x 17 7/8")F3 (as calculated by WinIsd): 30.5Dimensions of Outside of Box: 48" W x 16 1/16" Top x 23" Bottom x 18" HWhat do y'all think? What changes would y'all make?Thank you in advance for your time. Sorry for being such a pest! If I left something out or have a question just ask!
ckeeler11 Posted June 27, 2016 Report Posted June 27, 2016 I've read a few guys that have had good luck with port firing to driverside on the Ranger. Just a thought. not sure if you can make port work with that bracing or if you have room to let it breathe.
DLHgn Posted June 27, 2016 Author Report Posted June 27, 2016 I've read a few guys that have had good luck with port firing to driverside on the Ranger. Just a thought. not sure if you can make port work with that bracing or if you have room to let it breathe. That's one of the things I was worried about. I want to reduce the width of the port to help shorten it up and give more clearance and net volume but I'm worried the port area will start getting too small. I mean, it models well in WinIsd but I know that is not the end all be all.
DLHgn Posted June 29, 2016 Author Report Posted June 29, 2016 Can anyone say whether or not the port being that close to bracing will affect it?
Triticum Agricolam Posted June 29, 2016 Report Posted June 29, 2016 Can anyone say whether or not the port being that close to bracing will affect it? It's close enough that if it were me I'd probably change how the bracing was. You could make a cross out of two strips of MDF, and then orient it so the thin dimension is the same direction as the airflow. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
DLHgn Posted June 29, 2016 Author Report Posted June 29, 2016 Can anyone say whether or not the port being that close to bracing will affect it? It's close enough that if it were me I'd probably change how the bracing was. You could make a cross out of two strips of MDF, and then orient it so the thin dimension is the same direction as the airflow. So like a cross from the middle of the subs to the back and from left to right?
Triticum Agricolam Posted June 29, 2016 Report Posted June 29, 2016 A cross from between the subs to the back wall and from the top panel to the bottom. You will be bracing the same panels as your existing brace that way. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
DLHgn Posted June 30, 2016 Author Report Posted June 30, 2016 A cross from between the subs to the back wall and from the top panel to the bottom. You will be bracing the same panels as your existing brace that way. Oh ok, makes sense now. Would that be enough bracing for this box? Also, would this be enough port area and net volume? I know both are nearing the small side.
DLHgn Posted July 2, 2016 Author Report Posted July 2, 2016 A cross from between the subs to the back wall and from the top panel to the bottom. You will be bracing the same panels as your existing brace that way. Does this look okay to you?
Wasteland_Audio Posted July 2, 2016 Report Posted July 2, 2016 Idk about that, i foresee loading issues of your passenger side sub with that design.
