load350z Posted July 18, 2016 Report Posted July 18, 2016 How many batteries would i need to run 2 Incriminator 40.1s. I have a nissan altima with a 225a excessive amperage alt, but planning to upgrade to a 270a or bigger if i can find someone that makes a bigger alt for my car. I've been lookimg at northstar and xs power 12v batteries but dont know how many i need. Any suggestions will be helpful 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Nightshade Posted July 18, 2016 Report Posted July 18, 2016 At an absolute minimum I would try to run 5 group 31 batteries from either company that you mentioned. XS Power says that a D3100 can handle around 5K watts, so with 5 of them you can support a theoretical 25K watts but for only a short time. If you are going to be playing this on a daily basis it always helps to have the extra battery power available to use when you need it. I just added a D3100 to my car with the stock battery for the time being and I am not running much power at all. I have a Sundown SCV2000D and way more battery power than what is necessary to keep it happy. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
load350z Posted July 18, 2016 Author Report Posted July 18, 2016 Appreciate it 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
MrSkippyJ Posted July 18, 2016 Report Posted July 18, 2016 And get a good charger too, and use it often. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
load350z Posted July 19, 2016 Author Report Posted July 19, 2016 Even if i use the car everyday still get a charger? 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
MrSkippyJ Posted July 19, 2016 Report Posted July 19, 2016 A lot depends on how much you play it daily really. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
