mids to keep up with 4-6 ab xfl 1222s
Rich Schenk
Don't want to go with normal proaudio approach. not really sure which route i should go need mids to go with my substage 4 American bass xfl 1222s on dc 5k and eventually going to wall 6 American bass xfl 1222s on 2 dc5ks. thinking about going with https://www.madisoun...ool-cone/#tab-1 thinking two in each door to start out then eventauly 4 in each door off of my mmats sq4100 4x100 @4 ohms 4x110 @2 ohms 2x 220 @4ohms
or these 1 in each door to start out then save up and get another 1 per door so total of 2 per door not sure which would be louder and have better mid bass. http://store.soundsolutionsaudio.com/products/ssa-evil-6-5-mid-bass-speaker.html
Goal is to be loud and have good midbass any help on this or any other suggestions appreciated ty
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Bump for some veteran advice
Morning bump
Great speaker in the Silver Flutes you will not be disappointed. Look at a silk dome tweeter to match with them will sound nice and natural.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I have sb acoustics sb29rdcn-c000-4 one on each a pillar mounted on axis to driver . On a skar sk85.4
I don't feel like the Silver Flutes will be loud enough for you.
With so much bass, it will be hard to keep up ! And you plan to add even more !
I would look for a louder type of mids. But who knows?....They are cheap and sound good. It may be worth the try.
You'll need to work on the speakers install seriously if you want a lot of midbass : deadening, solid ring or baffle,...
Good luck.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
My sb acoustic mids had more mid bass than my Silverflutes, also sounded better as well.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Which ones jcarter can't find any reviews on them. That's why I'm undecided in which route to go 2 good mids per side or 4 cheaper mids per side. Sick of not hearing mids when turned up.
Going to fiberglass them in which will be fun . what do you mean by solid ring or baffle?
The speakers must not move when playing. You can't just put them on the door skin or on the stock speaker mounting baffle.
Fiberglass is for the look, it can be nice. But you can't count on the fiberglass to hold the speaker tight enough.
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
