Broke_Audio_Addict Posted August 8, 2016 Report Share Posted August 8, 2016 you for sure need to disconnect the speaker wires from the head unit. So that speed cable thing, you have it ran from the amp and tapped into your factory wires to power the speakers? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
JerryLZ Posted August 8, 2016 Author Report Share Posted August 8, 2016 you for sure need to disconnect the speaker wires from the head unit. So that speed cable thing, you have it ran from the amp and tapped into your factory wires to power the speakers? Yeah it was my fault I misunderstood the directions but like I said it was my first 4 channel amp install so I see how it works now. I had my speedwire basically hooked up as an addition onto my existing harness so all I need to do is disconnect the speaker +/- connections leading to my headunit and then my amp will be the only power source. I'll be reworking this tomorrow since I wanted to replace the RCA's with a nice pair instead of what I had laying around and I'm still waiting for the shipment so I'l see if everything goes well tomorrow afternoon and I should be up and running. Question: Would these speaker wires be considered signal wires? So I should run it along the other side of my truck with my RCA's away from my power runs? Link to comment Share on other sites More sharing options...
JerryLZ Posted August 10, 2016 Author Report Share Posted August 10, 2016 Problem solved. It was indeed the headunit wiring, I snipped the harness speaker connections and taped them off and wha la! I B JAMMIN. Thank for the help fellas Link to comment Share on other sites More sharing options...
Skullz Posted August 10, 2016 Report Share Posted August 10, 2016 Good deal, jam on. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
G-Difficult Posted August 20, 2016 Report Share Posted August 20, 2016 you for sure need to disconnect the speaker wires from the head unit. So that speed cable thing, you have it ran from the amp and tapped into your factory wires to power the speakers? Yeah it was my fault I misunderstood the directions but like I said it was my first 4 channel amp install so I see how it works now. I had my speedwire basically hooked up as an addition onto my existing harness so all I need to do is disconnect the speaker +/- connections leading to my headunit and then my amp will be the only power source. I'll be reworking this tomorrow since I wanted to replace the RCA's with a nice pair instead of what I had laying around and I'm still waiting for the shipment so I'l see if everything goes well tomorrow afternoon and I should be up and running. Question: Would these speaker wires be considered signal wires? So I should run it along the other side of my truck with my RCA's away from my power runs? yeah Link to comment Share on other sites More sharing options...
G-Difficult Posted August 20, 2016 Report Share Posted August 20, 2016 you for sure need to disconnect the speaker wires from the head unit. So that speed cable thing, you have it ran from the amp and tapped into your factory wires to power the speakers? Yeah it was my fault I misunderstood the directions but like I said it was my first 4 channel amp install so I see how it works now. I had my speedwire basically hooked up as an addition onto my existing harness so all I need to do is disconnect the speaker +/- connections leading to my headunit and then my amp will be the only power source. I'll be reworking this tomorrow since I wanted to replace the RCA's with a nice pair instead of what I had laying around and I'm still waiting for the shipment so I'l see if everything goes well tomorrow afternoon and I should be up and running. Question: Would these speaker wires be considered signal wires? So I should run it along the other side of my truck with my RCA's away from my power runs? yeah lol i didnt notice there was another page Link to comment Share on other sites More sharing options...
