ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 DSP unit is what you want. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
IH8PunkRok Posted August 20, 2016 Report Share Posted August 20, 2016 I would run the tweeters high pass at around 8khz on channel 1 and 2. The pro mids high pass at around 70khz on channel 3 and 4.I really hope you had a typo in this high pass the mids at 70khz lolAnyway these tweets don't look like they want to play low at all which sucks but crossing at 8k means they are playing jack squat. Even better the mids won't play all that high before they really start to break up. Your transition point should be set around 4-5k for these drivers. I honestly don't think it'll sound great but hey it's pro audio most people just want the loudness. Looking at the specs I'd say these should be ran as a 3-way but I digress. For the mids 100-4000 Tweets 4000+ Just make sure your ears are working when you are setting gains and tuning. You are playing with their limits at these settings. Also don't run rears. Imo they just complicate things -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 I recommended those as a safe starting point. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 Oh crap I just re read . 70hz not 70k sorry. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
G-Difficult Posted August 20, 2016 Author Report Share Posted August 20, 2016 SQ is kinda my goal. I just got the pros because I couldnt find any other mid rage drivers at the shops around me(they're pretty shitty)meaning all they had were coaxils and whole component sets and I figured if I order them might as well stick with RF. Imho, they sound better than the t2's I had. Anyways, you think the best would be to get some 4" drivers too? Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 I would stick with two way for now until you learn how they act. IMO unless you know how to make them work you would end up far away from sound quality. You can't just throw stuff together and expect it to work together. If anything you should get new tweeters and mids that are better suited to what you are doing. At the very least you will need an rta and a big eq to make it work. Again imo 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 20, 2016 Report Share Posted August 20, 2016 PPI has a nice looking set of 3 way components. I have not heard them myself but have seen a few people recommend them. This would give you a chance to hear a matched set with passive crossover so you would know how they are supposed to sound before going active. The Crossover has built in eq and attenuation as well as phase correction which means most of the hard work is already done for you. Going active without taking these into consideration is a step backwards for sq. Or just be happy with what you have, I'm sure it will do something. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
G-Difficult Posted August 20, 2016 Author Report Share Posted August 20, 2016 Thanks for all the help guys, I appreciate it. I'm new to this sight and I'm already loving it lol Link to comment Share on other sites More sharing options...
frogcase2002 Posted August 20, 2016 Report Share Posted August 20, 2016 For starting out running active I would get your self some cheap mids and tweeters from parts express or somewhere . You mite even be surprised and just keep them . Iv spent 20-30 bucks on mids and tweeters together befor that sounded alot better than some components iv heard. . Also dont run different speakers together on an amp Clarion cz702 Ssa evil mids and tweeters ppi 900.4 2 zcon 18s Taramps 10k 3 big dekas 1 xs 3 runs of 4/0 and big 3 300+ amp ohio generator 155.7 on dash at 36 (peak) 152 at 25 Link to comment Share on other sites More sharing options...
