defakadef7 Posted September 3, 2016 Report Share Posted September 3, 2016 I have a Hifonics BRX1116.1d and it pushing 2 SQ 212's about 1200 rms on those together and i have them wired to 1 ohm. So for the past month its starting to overheat and its being doing fine for about 4-months without ever going into protect mode until now. It goes into Protect mode and then 3-6 minutes it comes back on. I have a stock electrical system also. A local shop installed everything and they said everything is ok until i checked wiring myself. Is this a bad ground or what? Link to comment Share on other sites More sharing options...
3vil Posted September 3, 2016 Report Share Posted September 3, 2016 Looks like it could use some sanding. I'd also sand the backside of that seat belt mount and the area of the floor it contacts. Link to comment Share on other sites More sharing options...
DrewJones Posted September 3, 2016 Report Share Posted September 3, 2016 That ground is horrible. Wow. TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐ Link to comment Share on other sites More sharing options...
Skullz Posted September 3, 2016 Report Share Posted September 3, 2016 If the strut tower closer to the amp than the seatbelt location, i would switch it it to that instead, but if it is not than you really need to sand that down to bare metal for a better connection. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
