Wiring a single dual .5 ohm sub
Jhensley209
That would be wired in parallel at .25ohms, which is not recommended. Instead wire it in parallel, which would put you at 1 ohm (which on most amps is the lowest recommended impedance). Here is how to wire a single sub in parallel (ignore the ohms in the picture)
  • 1 year later...
1 hour ago, obyrd1983 said:
i need the same help but with 2 dual .5 subs
Series = 2ohm
series/parallel = .5ohm
Parallel = .125ohm.
  • Who's Online   0 Members, 0 Anonymous, 1426 Guests (See full list)
