Voltage Regulator
alrite so i was wondering if any1 has any experience in messing around with internal voltage regulators, what i want is to bypass my cars(06 gmc envoy) regulator and install an external 1 that way i could be in control of the voltage in my car if i want 15v i want to be able to do it from inside the cab at the turn of a dial....is this far fetched or is it possible? personally ive never seen it but i have heard of it, i have upgraded just about everything, the alt, big 3 bla bla bla n feel like this would be my last step, if its possible, n then im freakin done any input is highly appreciated.
06 Envoy
250a ALT
2x 2400 kinetiks
USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122
Taramp HD2500 for mid range
4xPioneer 6x9's 2x 1" Pioneer tweets
It would be possible. But 15v is not a lot more than the 14.7v that it does now.
Pioneer 80PRS
see thats my problem it doesnt go up more than 14.1-.2 n thats with no music, at full tilt il be lucky to get it stable at 13v
06 Envoy
250a ALT
2x 2400 kinetiks
Adding voltage isn't going to fix your voltage drop. Singer proved this with a video a while ago.
He had a 250 amp draw, setting the votlage to 15 he dropped to 13.2 and then he set the voltage to 13.7 and guess what he still dropped to 13.2
I would look at a different route if you are worried about voltage drop. i would suggest starting with big three, then look at upgrading alt, then if all else fails add more reserve.
last thing I would do in your case is change the voltage that is output at the alt
ive done the big 3 n 250a ho alt with over drive pulley n 2 2400 kinetiks, i was hoping that if i could raise the voltage a bit my system would be more efficient therefore not pulling as much amps to make the same amount of power they r now n be more stable, i guess i could always get 1 or 2 more batts if that will help, but ive always been under the impression that batts are more for when u have ur system on with the car off. am i wrong?
06 Envoy
250a ALT
2x 2400 kinetiks
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
