JMCDONALD2390 Posted September 14, 2016 Report Posted September 14, 2016 So I'm looking to do a box redesign and I need a little help. I'm looking to go with a ported box for two Rockford P3D4-12's. My available space is 16 High, 37 Wide and 15 deep. I'm looking to tune at 30-35 hz . Any help would be appreciated.
Triticum Agricolam Posted September 14, 2016 Report Posted September 14, 2016 You probably need more space. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
JMCDONALD2390 Posted September 14, 2016 Author Report Posted September 14, 2016 According to Rockford 1.79 cubes per sub is optimal.
Triticum Agricolam Posted September 14, 2016 Report Posted September 14, 2016 According to Rockford 1.79 cubes per sub is optimal. Yes, and you don't have that much space. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
sTp Posted September 14, 2016 Report Posted September 14, 2016 Right i just punched your measurements in to Torres and you got a Gross volume of 4.02 cuft and that's without woofer displacement and the area for the port so you won't have enough room just like Triticum said. Is there anyway you can get some more room in your trunk?
JMCDONALD2390 Posted September 14, 2016 Author Report Posted September 14, 2016 It's going in a 2014 Dodge Dart. The depth could be increased, but I would need to assemble the box in the car.
Joe X Posted September 15, 2016 Report Posted September 15, 2016 Here is a suggestion, firing back, don't think the 3 extra inches will be a problem for you but test it, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
JMCDONALD2390 Posted September 15, 2016 Author Report Posted September 15, 2016 Thanks, i'll give this one a try.
