Jonathon Trahan Posted September 16, 2016 Report Posted September 16, 2016 Ok so im pretty new to car audio and I figured I would ask somewhere I know people could answer what is probable a simple question, bare with me.I have a 2012 VW Golf with a Dynaudio Package and newly installed Rockford Fosgate Prime 1200. I had the guys at Zenclosures build me a box with two chambers for two 10's the box they offer is here :http://www.zenclosures.com/2006-11-Volkswagon-GTI-Subwoofer-Box-p/vwgti0611.htm Now I have 2 RE audio SR pro 10 in subs specs are here : http://reaudio.com/products/woofers_re_pro_sr.php From what i gather i have far to much airspace for either sealed or ported, Would it be smart to try to fill the box with something to get rid of the air space? And at that point could i convert said box to a ported box ? Just wanted and idea on how to make sure i do it right.
bassl0va Posted September 17, 2016 Report Posted September 17, 2016 Is that box 1.9 cubes PER sub!? With port displacement it might end up a suitable volume. If not, stick some 2x4 in as bracing to take up a bit more space. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
MADVIBES Posted September 17, 2016 Report Posted September 17, 2016 i say rock the subs sealed in that box size, you will appreciate the freq extension, you are not running a ton of power so I wouldnt worry too much about over excurting the drivers. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Jonathon Trahan Posted September 17, 2016 Author Report Posted September 17, 2016 Is that box 1.9 cubes PER sub!? With port displacement it might end up a suitable volume. If not, stick some 2x4 in as bracing to take up a bit more space. The way the site has it worded its like 1.9^3 so i think thats only if i chose to put three subs? as the inside only has 2 chambers im guessing that means i have 2.85 per chamber
ckeeler11 Posted September 19, 2016 Report Posted September 19, 2016 If you want you could add in 2x4's to take up space. it looks like you have 1.9 per sub so that is quite a bit more than what is recommended.
_paralyzed_ Posted September 19, 2016 Report Posted September 19, 2016 Is that box 1.9 cubes PER sub!? The way the site has it worded its like 1.9^3 That stands for 1.9 cubic feet, not the number of subs
Jonathon Trahan Posted September 19, 2016 Author Report Posted September 19, 2016 Is that box 1.9 cubes PER sub!? The way the site has it worded its like 1.9^3 That stands for 1.9 cubic feet, not the number of subs No no I know that but what I mean is the way its worded it could be per chamber or total its not really clear
_paralyzed_ Posted September 20, 2016 Report Posted September 20, 2016 It's very clear. It says total volume. The total volume is 1.9^3 so you have .95^3 per chamber with two chambers.
ckeeler11 Posted September 20, 2016 Report Posted September 20, 2016 It's very clear. It says total volume. The total volume is 1.9^3 so you have .95^3 per chamber with two chambers. Are you sure? it uses the same description whether you choose 1x10, 2x10, 1x12, or 2x12.
_paralyzed_ Posted September 20, 2016 Report Posted September 20, 2016 Look at the box in the picture. That is the box. It looks to me like it is a 1.9 cubic foot box. Do you know how large a 5.7 cubic foot box is? (1.9 x 3) There is no way in hell that box is 5.7^3.And it clearly states "total volume", not volume per chamber.
