Triticum Agricolam Posted September 18, 2016 Report Share Posted September 18, 2016 How were your gains set? That amp should be capable of putting out somewhere around 50 volts. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 clamp the power going into the amp on dc setting and do a burp, leave your dmm on the speaker wire set to acc for shits and giggles will go back out there in a lil when i get a chance 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 How were your gains set? That amp should be capable of putting out somewhere around 50 volts. when i did the 40hz the gain was little over half way up, when i did the 30hz test tone i too it lil over 3/4 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted September 18, 2016 Report Share Posted September 18, 2016 So you are just setting them arbitrarily? Not a great idea. The right the way to do it is using something that can detect clipping/distortion, like a DD-1 or oscope. It will let you get max power out of your amp without damaging stuff. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Jessica Posted September 18, 2016 Report Share Posted September 18, 2016 according to your numbers you are seeing 1.6ohms while playing. which is weird. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 So you are just setting them arbitrarily? Not a great idea. The right the way to do it is using something that can detect clipping/distortion, like a DD-1 or oscope. It will let you get max power out of your amp without damaging stuff. ur def right about that, right now im only using the clip indicator on the amp, but as soon as i see the clip light id turn it down 1 on the deck till the clip light is gone but still this amp should still put out more than 500watts right? something is wrong with my setup 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 according to your numbers you are seeing 1.6ohms while playing. which is weird. maybe a blown voice coil? 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MADVIBES Posted September 18, 2016 Report Share Posted September 18, 2016 wait a sec, if i recall I saw a video about taramps giving off electromagnetic fields that effect clamp meters. try and clamp the speaker wire as far as possible away from the case or do what he did in the video which was to run a ground to the heatsink and this made the emf stop. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted September 18, 2016 Report Share Posted September 18, 2016 ur def right about that, right now im only using the clip indicator on the amp, but as soon as i see the clip light id turn it down 1 on the deck till the clip light is gone but still this amp should still put out more than 500watts right? something is wrong with my setup Well at least you have clip light. Since your impedance isn't at one ohm you aren't ever going to get the full 2500 watts no matter what. You don't have to get the full listed wattage to get full power out of an amp though, and rarely will you. At 28.9 volts you are getting the 1 ohm equivalent of 835 watts, still a long way from 2500, but better than 500. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
hispls Posted September 18, 2016 Report Share Posted September 18, 2016 wait a sec, if i recall I saw a video about taramps giving off electromagnetic fields that effect clamp meters. try and clamp the speaker wire as far as possible away from the case or do what he did in the video which was to run a ground to the heatsink and this made the emf stop. I have also heard rumors that some Brazilian amps aren't allowed in certain competition classes which go by clamped power since there's something that goes wrong when trying to clamp them. Doesn't sound terribly logical to me, but who knows? Also that amp should be able to make 50V if it is supposed to do rated power. Link to comment Share on other sites More sharing options...
