alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 wait a sec, if i recall I saw a video about taramps giving off electromagnetic fields that effect clamp meters. try and clamp the speaker wire as far as possible away from the case or do what he did in the video which was to run a ground to the heatsink and this made the emf stop. i did have the clamp very close to the amp i hope that what it is cuz im very puzzled by this....n my hcca slams i get window flex n everything its nice n tyte 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 ur def right about that, right now im only using the clip indicator on the amp, but as soon as i see the clip light id turn it down 1 on the deck till the clip light is gone but still this amp should still put out more than 500watts right? something is wrong with my setup Well at least you have clip light. Since your impedance isn't at one ohm you aren't ever going to get the full 2500 watts no matter what. You don't have to get the full listed wattage to get full power out of an amp though, and rarely will you. At 28.9 volts you are getting the 1 ohm equivalent of 835 watts, still a long way from 2500, but better than 500. yeah thats a very long way from 2500 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 i was also thinkin maybe bad multimeter n clamp or something but then again my batter was discharging pretty fast so thats the only thing im really stuck on rite now i cant get my mind off of it 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MADVIBES Posted September 18, 2016 Report Share Posted September 18, 2016 http://dioguardoengineering.com/collections/all this is the guy, he posted a video about taramps. on you tube i think or facebook, I cant access either of them otherwise I would send you a link to the video DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 18, 2016 Report Share Posted September 18, 2016 Are you clamping one speaker wire or both? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 Are you clamping one speaker wire or both? only the positive 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 lol guys dont laugh but i figured out what i was doing wrong yesterday, i had the clamp around the 1 n only positive speaker wire which is right but the dmm i had on the power input of the amplifier...i guess u can call me dumb i didnt figure this out till midnite last nite n was just sitting there like wait a f******g min y would i hook it up to the power input when im checing for output LMFAO... 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 i just checked it n it was 60.x on the dmm n 20.x on the clamp so lil over 1200w on a 3ohm load @ 40hz 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted September 18, 2016 Report Share Posted September 18, 2016 If you are getting over 60 volts on the sub outputs I'd be very happy with that. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
alibaba Posted September 18, 2016 Author Report Share Posted September 18, 2016 If you are getting over 60 volts on the sub outputs I'd be very happy with that. it sure took a load off my mind, now i just have to beef up my electrical even more im waiting for my ct 4000.1 to come in the mail sometime next week so i gota get ready n get more batt reserve. speaking about the ct 4000 it has dual power inputs, so do i run 2 runs of 0ga from the front battery into the 1 in the trunk or should i just laeve the 1 run of 0ga how it is now n just have 2 runs from the battery in the trunk? 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
