akuma4u Posted September 18, 2016 Report Posted September 18, 2016 was going to do a trunk build on 2 sa 12s which i still have , - currently running one OR a trunk build on a single zv3 15 but the guy who was going to do the build turned out to be unreliable and it will never happen. so i have no choice i have to scrap the trunk build plans and build a box and slide it into my small ass trunk (its really the trunk opening that is the problem not so much the trunk itself) I aimed for getting the best sub for the power i have so I ended up buying a zv3 12 d2 and will be running it on 2000-2200 rms @ 1ohm so i need help with building an enclosure my max height is 13.5 to 14 inches max width would be like 28-32 max width would be around 14-16 sundown recommends no more than 2 cubes NET tuned to 35hz i am aiming for hitting the widest frequency band possible while still being super loud... i have music thats in the low 40s all the way up to the mid/high 50s , and of course there are some songs/parts of songs that dip into the 20s and 30s too. any designs and help would be highly appreciated. thanks in advance!!
MrSkippyJ Posted September 18, 2016 Report Posted September 18, 2016 Holy shit dude, give it some time. It's early on a weekend. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
akuma4u Posted September 18, 2016 Author Report Posted September 18, 2016 Holy shit dude, give it some time. It's early on a weekend. sorry for impatience - box builder wants to meet me for deposit today and was asking me to forward design for this sub as he is not familiar with it..
sTp Posted September 18, 2016 Report Posted September 18, 2016 Right just a few questions are you wanting sub rear port rear? and i would tune around 33hz should give you a nice bandwidth according to sundown they recommend 32hz tuning. ZV3 12" Ported 2.0 ft^3 Displacement 0.21ft^3 Depth 8.75" Outside Diameter 12.625" Cut-Out 11.125" Recommended Tuning 32hz Recommended Port Area 32 in^2 That's there recommended.
akuma4u Posted September 18, 2016 Author Report Posted September 18, 2016 Right just a few questions are you wanting sub rear port rear? and i would tune around 33hz should give you a nice bandwidth according to sundown they recommend 32hz tuning. ZV3 12" Ported 2.0 ft^3 Displacement 0.21ft^3 Depth 8.75" Outside Diameter 12.625" Cut-Out 11.125" Recommended Tuning 32hz Recommended Port Area 32 in^2 That's there recommended. ya i saw those recommendations but u know how sometimes the manufacture has its recommendation but then individuals fool around and tweak stuff and find that other dimensions work out way better.. if someone has done this and found going a little smaller or bigger or tuning a lil higher works out better than their recommendation then pls let me know.. or if their recommendation is spot on then let me know too.. im not sure how accurate sundown is with their box specs and recommendations.. i know some other companies are off/way off and going bigger/smaller than what they suggest works out way better.
sTp Posted September 18, 2016 Report Posted September 18, 2016 Well is if sundown is right with there recommended specs i have pretty much designed a box tuned to 33hz and 2 cuft net. So if its right will just keep a eye out on this thread and post the design
akuma4u Posted September 18, 2016 Author Report Posted September 18, 2016 Well is if sundown is right with there recommended specs i have pretty much designed a box tuned to 33hz and 2 cuft net. So if its right will just keep a eye out on this thread and post the design go ahead and post it bro just keep in mind it should be under my max dimensions which i have stated in my first post. thanks
sTp Posted September 18, 2016 Report Posted September 18, 2016 Yeah its under your max dimensions box is Height = 14 Width = 31 and Depth = 16 if you do go ahead and build it make a template with cardboard before you build it to make sure it fits in your trunk. Also what car is it going in? Will post it ASAP just finishing it off in sketchup now.
akuma4u Posted September 18, 2016 Author Report Posted September 18, 2016 Yeah its under your max dimensions box is Height = 14 Width = 31 and Depth = 16 if you do go ahead and build it make a template with cardboard before you build it to make sure it fits in your trunk. Also what car is it going in? Will post it ASAP just finishing it off in sketchup now. its going into a genesis coupe. the depth is 16 WITH double baffle right?
