installing an equalizier
alibaba
k so im installing an equalizer and it might be a odd question but theres reasons behind it, can u install the EQ from the battery i have in the trunk? run power/ground from battery in the back n then take the rca's that go to the amplifier plug the in directly to the EQ n then from the EQ to the amplifier?
im just sick n tired of taking my dash apart.....in the past month or so i prolly took it apart like 15 times no joke prolly more any input would be appreciated, by the way the EQ is also a 9v line driver
06 Envoy
250a ALT
2x 2400 kinetiks
USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122
Taramp HD2500 for mid range
4xPioneer 6x9's 2x 1" Pioneer tweets
If it's a trunk mount EQ, sure you can do that. The downfall is not getting the higher driven signal from front to back. Otherwise it'll work fine. Best to use the same power and ground points that the amps are using.
Static drops are my bag.
so in other words it wont sound as good or?
06 Envoy
250a ALT
2x 2400 kinetiks
also there are 2 inputs on my eq, Input 1 n input 2,from my head unit which rcas do i hook up to the EQ, i just want to be able to control my subs from it for now
06 Envoy
250a ALT
2x 2400 kinetiks
any1?
06 Envoy
250a ALT
2x 2400 kinetiks
What kind of eq?
Pioneer 80PRS
What kind of eq?
Hifonics HFEQ
06 Envoy
250a ALT
2x 2400 kinetiks
How do you plan to use it for sub level if it's mounted in the trunk?
You should probably read the directions that come with it. The second input could be an auxiliary input. Or it could have front and rear inputs. Maybe try one set and then the other to see what it does.
Pioneer 80PRS
How do you plan to use it for sub level if it's mounted in the trunk? not going to mount it in the trunk i was going to run the wires from my battery to the EQ n the rca's that go into the amp into the EQ then from the EQrun rca's to the amplifier....idk wtf im doin i just want this thing done as painless as possible man
06 Envoy
250a ALT
2x 2400 kinetiks
  • Who's Online   0 Members, 0 Anonymous, 1090 Guests (See full list)
