Opinions on these speakers please
Zak.vr6
There's many online retailers that stock this. "Tymphany 830946"
What are you thinking of using it for? It might make an ok mid-bass but isn't really suited for IB use. Can't be used as a woofer in a 2 way though, it needs a low pass at like ~300hz, could go higher with a steep filter.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Infinite baffle, which is how most people run door speakers. As in, they are just open into the cavity of the door, rather than having an enclosure.
The qts is too low for IB really. Could work ok if you're willing to make pods for them.
Thank you
I do have a slight problem with moisture with really heavy rain
Hence why needing replacements, to rectify the moisture I do need to build some kind enclosure in to the door
These will get replaced(moved to rear doors) once I've saved up for some decent 3way components
Yeah Parts Express or Madisound should list suggested volume for their enclosure, otherwise I can suggest something if they don't.
What are these replacements to? As I said they aren't suitable for use with a tweeter, breaks up around 1khz then drops like a stone. You should have it crossed over an octave or 2 before that depending on crossover slope
They will be replacing some genesis audiophile a16 that came with the car
I've never heard of them before nor can I find there specs
But they seem to get good SQ reviews
They did sound ok once I had used an amp on them (Kenwood kac5201 40w rms per ch)
I would rather fix the moisture issue and make an enclosure in the front doors to get as much lows possible up front without going over the top
Simple and effective if that's possible lol
  • 4 weeks later...
I think Genesis is a high end British brand. they sell very expensive amps.
Those speakers look promising, better than the ones you're replacing them with.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
  • Who's Online   0 Members, 0 Anonymous, 1530 Guests (See full list)
