i have notice that my batt in my trunk was at 11volt but the 1 under hood was at 12.5 so what can i do to fix dat also with the car runing my alt is only puting out 13.5 but when i disconnet my 4ga wire runing to my batt out back the volts go up to 14.5 so what can i do so that my volts stay the same .also im runing my deck,eq,1 audiobahn a2200 hct,1fockfordfosgate punch 800.4 tv tuner,7" tv,dvdplayer,ipod controler,ps2,power inverter, all of that is ran off my batt in my trunk.also which is better to have more volt or amps or both
Upgrade to 1/0ga wire.
More runs of wire from the front battery to the back battery.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
to be runnin all that electrical that u say ur runnin u definitely need a HO alt atleast 250amps or more... cuz all that electrical is drawing so much current that you alt is strugglin to keep a good charge hence the low voltage readin at ur batts, also if u runnin just 4gauge wire then u need to get atleast 2 runs of 1/0awg and do the big3 if anything plz do the big three
Edited by KWP369
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
first thing you need to do is trickle charge the back battery overnight.
You do need to upgrade the power wire to the back battery and do the big three next.
If you are still having voltage drop between the batteries then it is time for a HO alt.
What kind of batteries are you using, are they atleast the same type (AGM style). Batteries don't have to be the same but it helps keep them evenly charged.
Im Running a red top autozone under my hood an 2 oddesey 1200 in my trunk
also i jus install my 200 amp alt that came off of my corsica an now im getting 13.5 to all of my batts but is dat gonna be ok or do i need more also what ga wire should i be runing off of my batt in my trunk to power all of that my deck,eq,tv tuner,7" tv,dvdplayer,ipod controler,ps2,power inverter dats installed .also do anyone know who makes a dual alt braket for a chevy 305 tbi
Edited by Crazy For Hertz
Use 1/0gauge for sure. That voltage is still low what year and make. When you add a batteries your voltage should rise from the alt due to the more draw. Factory should be atleast 13.8 - 14v with that much draw.
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
  • Who's Online   0 Members, 0 Anonymous, 965 Guests (See full list)
