I know there's a thread on CACO about everything 4th orders but im not about to read through like 500 pages...im doing a 4th order wall for my teammate and i wanted to try my hand at designing it (never designed a 4th so bare with me)..built dozens but never designed...what size ports do you normally go with as a good starting point to begin testing? Ive heard between 1/4-1/2 cone area
8 Audio Legion S2512's
2 Audio Legion 5000D
i ran the EBP (92.96) on these and it looks like they are on high side and would like a 6th better but we're trying the 4th as that's what he wants..im told i shouldnt run into mechanical issues by this, but will possibly result in a peaky enclosure
any input from people with EXPERIENCE would be great...and NO, dropping down the amount of subs and going to a 6th, or changing subs, is NOT an option right now...if it fails, it fails and he upgrades...but we are trying this until that point
the design i came up with came out to about 2.4:1 ratio, just under 8cu sealed and 20cu ported, with around 480sq of port to start...it can be adjusted bigger or smaller as needed with 2x4
[imgur](http://i.imgur.com/SLdETX7.jpg)
personal build in progress
http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/
www.facebook.com/TurbulentDesigns
You are probably better off for not reading that thread on CACO, there is more than a little misinformation there.
I agree with what other people told you, you shouldn't have mechanical issues, but the box will probably be quite peaky.
480 sq in of port area probably isn't a bad starting point. You could probably cut back to 400 if you needed, but I'd stay at 480 if you can.
As with any bandpass box, its a good idea to plan ahead for changing the length of the port to tweak the tuning for better performance.
Builds:
The whole port will be available..the picture I used was just where I think a good starting point will be...I'm gonna test peak without a port when I begin so that'll help some to understand what I'll need..but the whole ported section is available to change the port with 2x4
