CobraGolf Posted October 5, 2016 Report Posted October 5, 2016 okay guys i know there are threads all over for this but we all know the vehicle specific thing. i made a thread about my altima coupe shortly ago and decided i will be running sa10s ported. i will be using a memphis 1000 watt amp with an upgraded battery. dimensions we have about 13 height 30 wide 20 deep. can stretch depth or width a little if need be but thats max height. wanting tuned 33-34 hz. any suggestions qill be greatly appreciated.
300824 Posted October 5, 2016 Report Posted October 5, 2016 i run 2 SA 10's on a audio technix AT 1200.1 @ .5 ohm (same as Ct sounds 1400.1) box is 3 cuft net 2) 4'' aeros tuned to 33hz they will need a lil more power than what you plan to have... car is a 97-03 grand prix.
Joe X Posted October 5, 2016 Report Posted October 5, 2016 Here is a suggestion, firing back, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
ckeeler11 Posted October 5, 2016 Report Posted October 5, 2016 i run 2 SA 10's on a audio technix AT 1200.1 @ .5 ohm (same as Ct sounds 1400.1) box is 3 cuft net 2) 4'' aeros tuned to 33hz they will need a lil more power than what you plan to have... car is a 97-03 grand prix. you are killing your output with those small ports. You should be running 2 6" ports
CobraGolf Posted October 5, 2016 Author Report Posted October 5, 2016 thanks joe. that was close to what i waa thinking was just unsure of the port wpace. appreciate it very much
CobraGolf Posted October 5, 2016 Author Report Posted October 5, 2016 Here is a suggestion, firing back, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. what does the cu ft and tuning come out to in that design?
300824 Posted October 5, 2016 Report Posted October 5, 2016 i run 2 SA 10's on a audio technix AT 1200.1 @ .5 ohm (same as Ct sounds 1400.1) box is 3 cuft net 2) 4'' aeros tuned to 33hz they will need a lil more power than what you plan to have... car is a 97-03 grand prix. you are killing your output with those small ports. You should be running 2 6" ports im doing 145's (term lab) on music.. have lil over 9" portarea per cube
Triticum Agricolam Posted October 5, 2016 Report Posted October 5, 2016 im doing 145's (term lab) on music.. have lil over 9" portarea per cube Imagine how much louder you could be if you had enough port area :-) "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Triticum Agricolam Posted October 5, 2016 Report Posted October 5, 2016 what does the cu ft and tuning come out to in that design? It says right at the top, Fb = tuning frequency, Vb = net volume. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
300824 Posted October 7, 2016 Report Posted October 7, 2016 im doing 145's (term lab) on music.. have lil over 9" portarea per cube Imagine how much louder you could be if you had enough port area :-) well the whole goal wasnt to do "numbers" its a daily driver that sounds good.. feel free to design something using 6" aeros box can be no bigger than 36 wide 11 high
