TezasBassBox Posted October 8, 2016 Report Posted October 8, 2016 To play not being charged for 8 hrs.two 5-1/4, one radio, one 80w boss amp and a 12 kicker comp. This setup is going on my little boat. Subs don't hit when powered by cheap amps!
Mitchaford Posted October 8, 2016 Report Posted October 8, 2016 What battery(s) do you have? 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
TezasBassBox Posted October 8, 2016 Author Report Posted October 8, 2016 Just a group 24 Duracell deep cycle Subs don't hit when powered by cheap amps!
TezasBassBox Posted October 8, 2016 Author Report Posted October 8, 2016 I was hoping someone could suggest a battery(s) that will work. Subs don't hit when powered by cheap amps!
ShadeTreeMechanic Posted October 8, 2016 Report Posted October 8, 2016 Its really hard to say how much power it will take. It depends on how loud you will be playing it and how much power the amp puts out and the amps efficiency etc. Are you going to play it until it gets down to 11v, 10v, or until it shuts off? There are too many variables. Just keep adding batteries until it plays as long as you want. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
TezasBassBox Posted October 8, 2016 Author Report Posted October 8, 2016 Thanks Subs don't hit when powered by cheap amps!
