Lanzer opti 700x2
crownvictoria31
Just want to point out that I also have a ACC relay installed. This is how I have it connected
87-12+ which is hooked up to one of the amps positive input.
86-remote turn on lead which is the radio blue wire
30- goes to the amps, 2 fans and audio control matrix
85-ground
I believe this is correct?
So i checked the grounds with the fluke. If im doing it right which is put the nevative probe on the negative terminal and with tue positive probe, put on each ground point, readings im getting is negative to frame= 0.2
Negative to alternator housing= -0.5
Negative to chassis= 0.2
Negative to engine block = -0.2
So im getting - readings and normal readings. Whats causing this and is all this right?
Those readings look normal. If you put the test leads together by themselves you would probably get .2 ohms. Can you post some pics of the system so we can get an idea of the layout? Maybe even a video of the noise problem when it happens? Someone might see a clue to point us in the right direction.
Pioneer 80PRS
The relay sounds right but I don't have one in front of me to verify at the moment.
Pioneer 80PRS
If it does it with the engine off then you can rule out the alternator too.
Pioneer 80PRS
I will try to get a video but i need to install the audio control for this cause thats when its really doing it. So i just swapped over my stock altetnator and same still happenning. So alternator being ruled out. My grounds are solid. Checked the grounds by the amp and they both at 0.2. I am going to try my audio control on my friends system and see what happens. Who gives that it might be that.
One question about the audio control matrix I have is
I did notice that when I was plugging in the RCA's to the input of the audio control, I was maybe about 1/2" away from plugging the rca in and I was already getting sound from the matrix. I kinda thought this was a little crazy.
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
