grounding front to back question
I have a unibody car, 08 grand prix. do you recommend grounding from the rear you the front to either the alt or battery? or does it not matter.
It depends on how much power you are running.
Pioneer 80PRS
With 5k you would want to ground to the body as well as a dedicated ground front to back. Are you planning to run an H.O. alt?
Pioneer 80PRS
For sure the big3 or 4. Amp to chassis, and if you have enough 1/0 or 2/0, go straight back to the negative terminal on your starting battery. If you don't have enough to run to the front, negative to the chassis is ok too
  • Who's Online   0 Members, 0 Anonymous, 4539 Guests (See full list)
