T line design
ToNasty
Home or vehicle use? How much power are you going to run?
Builds:
Tuning? That 19hz fs is ridiculous
Also this will be a huge box. 21 cubes for a quarter wave @ 19 hz and that's just chamber space
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
There are definitely different schools of thought when it comes to T-line design.
To save space you can taper the line. This also makes it perform like its longer than it really is, which also saves space. You don't have to make the line equal cone area either. Reducing it a bit can help smooth out the frequency response, though every sub is going to perform differently.
A T-line starting with 176 sq in of area and tapering down to 88 sq in, 141" long should work well. This results in an internal volume of about 10.5 cu ft, still big but not as huge.
Builds:
What dimensions do you have to work with?
Builds:
Here is what I came up with:
That's just a profile view. It assumes a 20.5" internal width. I was able to get a 139" long line, which is about as close as its going to get to the target of 141". These tapered lines are a pain in the ass to layout.
Here is what the raw output looks like:
And here is the cone excursion based on 1,000 watts of input power:
With this enclosure it would take about 2,400 watts to reach xmax at the excursion peak around 30 Hz.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 416 Guests (See full list)
