Roof dents from wall build
dsw422
Hey guys.. doing a wall build now in the members page and had a question.. I just noticed that the roof of the car where I glued the roof panels too have sucked in some.. u can't tell too much in daylight, but at nighttime, u can tell.. I am wondering if this is a common thing..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
That usually happens from using Great Stuff when you spray it all at once and trap the air inside so it has no where to go.
Which is why you do small sections at once and let it cure and expand before doing another spot.
Otherwise your left with soft foam that cant expand due to being air tight and you get dents from where it sucks out the air and forms a vacuum.
I've never seen that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks.. I didn't think about that.. then again the space was no more than 3/4 of an inch in each of those spots.. I didn't even use half a can for the roof in those spots..
1994 Ford Bronco
Sony door speakers
It's not as bad as it looks.. lol.. it's at most 1/8 of an inch of a dent.. like I said, at night it looks terrible.. daytime u can't even tell unless u feel it..
1994 Ford Bronco
Sony door speakers
You can drill through the wood where your dents are to allow air in and possibly push the roof back up with a wooden dowel or even a screw driver, then plug the holes good a couple days later once the foam is cured.
Probably too late for that?
1994 Ford Bronco
Sony door speakers
Not at all, just get yourself a 1/2 ish sized spade/speed bit and make a few holes.
They are typically long enough to go through several layers of wood.
Just continue to check the depth your drilling so you dont go through the roof.
Ok.. I have a ton of those bits.. I'll try that.. thanks
1994 Ford Bronco
Sony door speakers
I just went through this. Used the same type of bit, drilled some holes, used a coat hanger and a hack saw blade to cut the foam between the board/roof where the dents are. Give it a day or two for the metal to take its shape back, then refill with foam in those places.
  • Who's Online   0 Members, 0 Anonymous, 859 Guests (See full list)
