Roof dents from wall build
dsw422
I just went through this. Used the same type of bit, drilled some holes, used a coat hanger and a hack saw blade to cut the foam between the board/roof where the dents are. Give it a day or two for the metal to take its shape back, then refill with foam in those places.
Awsome.. thanks for giving me hope.. lol
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
Ok.. so I drilled the holes and let it sit a couple days, but the metal only formed back slightly. Think a plunger could help?
1994 Ford Bronco
Sony door speakers
Maybe try some compressed air in the hole. Wrap a rag around the end of your blow gun and stick it in the hole. I have used this method to unclog sink drains too.
Pioneer 80PRS
Ok.. so I just tried this.. I worked on 2 of the spots. Though 1 will pop back if u touch it.. how do I prevent this?
Also, the other 2 haven't moved.. they aren't air tight like the others were so the air was escaping instead of pushing on the metal.. any ideas?
Thanks
1994 Ford Bronco
Sony door speakers
You will usually have to drill a hole big enough to go in the hole with a 3/8 to 1/2 inch diameter wooden dowel or something similar like I said in my previous post.
Drilling the holes alone will not always work because you have other foam that has attached itself to the roof and the wood forming a bond.
So when you use a wooden dowel that fits in the hole you can easily break that bond apart. You want to use a dowel because its a flat end that wont puncture through your roof as easily as something like a screwdriver would.
Once you got the dent pushed back out go and squirt a little foam as far as you can away from the whole so it can expand and get fresh air from the hole you drilled.
Once that foam hardens you can try and do another decent squirt and let that cure, and then do another filling the hole closed which will most likely expand or drip out of the hole until it is fully cured.
  • Who's Online   1 Member, 0 Anonymous, 1379 Guests (See full list)
