BMS Posted November 11, 2016 Report Posted November 11, 2016 So my boxes have been working out quite well I built one for 2 massive summo 64's and one for a skar vvx 12. the vvx 12 was very much to spec the summo 64's were definitely not but both still turned out great now I am going to build a ventd box for a re audio xxx 15. here is the recommendation http://reaudio.com/products/BOX%20V2%20PDF/XXX%2015%20VENTED(1).pdf. now is it just me or does it recommend i tune to 27 hz which i like but the port area is 16 sq inches for a 2.7 vb box that is really small why can i go 45 square inches of port area i know that the port will get like 40 inches longer thats not a problem is there a reason they recommend 16 square inch? how do i know if it is a v1 or a v2 i din't see it labeled.
frogcase2002 Posted November 11, 2016 Report Posted November 11, 2016 Yea seems way small Clarion cz702 Ssa evil mids and tweeters ppi 900.4 2 zcon 18s Taramps 10k 3 big dekas 1 xs 3 runs of 4/0 and big 3 300+ amp ohio generator 155.7 on dash at 36 (peak) 152 at 25
MADVIBES Posted November 11, 2016 Report Posted November 11, 2016 if your port becomes longer than 20" it starts to act like a pipe organ than an actual port. whats the xmax of the driver that is being used in this design? DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
BMS Posted November 11, 2016 Author Report Posted November 11, 2016 yeah the box too (vb) it is 54 mm one way yeah alot. elaborate on the pipe organ i had a 48 inch port once sounded fine.
frogcase2002 Posted November 11, 2016 Report Posted November 11, 2016 if your port becomes longer than 20" it starts to act like a pipe organ than an actual port. whats the xmax of the driver that is being used in this design? Usually with the correct port area for a sub its longer than that Clarion cz702 Ssa evil mids and tweeters ppi 900.4 2 zcon 18s Taramps 10k 3 big dekas 1 xs 3 runs of 4/0 and big 3 300+ amp ohio generator 155.7 on dash at 36 (peak) 152 at 25
MADVIBES Posted November 11, 2016 Report Posted November 11, 2016 wow, ok just looked at that box, thats a pretty lame factory design. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Triticum Agricolam Posted November 11, 2016 Report Posted November 11, 2016 yeah the box too (vb) it is 54 mm one way yeah alot. elaborate on the pipe organ i had a 48 inch port once sounded fine. Madvibes is right, if a port gets too long you can have issues with pipe resonance. How much of a problem it will be depends on how long the port is and high of frequencies you are sending to your sub. A 20" long port will have a resonance at about 170 Hz, a 40" long port will resonate at about 85 Hz. I try to keep ports from getting much over 40", but I've done quite a few close to or at 40" without issues. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
MADVIBES Posted November 11, 2016 Report Posted November 11, 2016 when I think of ports being that long I start to think of TL designs and not actual ported in its normal sense, atleast thats my gut feeling on the situation anyway DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
