So i want to trade this for a decent set of 12's or a 15" woofer. i used the amp for around 2-3 months pushing one Kicker 12' CVR i sold the cvr now lookin to trade this amp it comes in box with all supplied hardware
---It powers out 360 watts when driven at 2 ohms - drive it hard, and you can even get up to 800 watts maximum. Plus, it delivers some important features for fine-tuning your system, namely selectable 50Hz bass boost and a built-in crossover. It also comes with oversized power terminals, speaker level inputs, and a wide input level of 400mV to 6.5V.---
Product Description:
* 800W Max, MonoBlock Amplifier
* RMS Power Output:
o 4 ohms: 250 watts x 1 channels
o 2 ohms: 360 watts x 1 channels
* PWM Regulated MOSFET Power Supply
* Screw-Type Speaker Terminals
* Balanced Isolator Input Circuit
* RCA Inputs
* Speaker Level Input
* Input Level Control
* Built-in Crossover
* Crossover Frequency Range: 40 Hz - 240 Hz
* Bass Level Control: 50 Hz
* Frequency Response: 10 Hz - 240 Hz
* Dimensions: 11-13/16"L x 13-1/8"W x 2-3/8"H
Amplifier Specifications:
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 250 watts x 1 channel
* RMS Power (2 ohms) 360 watts x 1 channel
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 800 watts
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged Not Bridgeable ohms
* THD at Rated RMS Power 0.03%
* Speaker Level Inputs Yes - 2 pair
* Preamp Outputs Yes
* Built-in Crossover Yes - Variable LP
* High-Pass Crossover Frequency N/A
* Low-Pass Crossover Frequency 40 - 240 Hz
* Subsonic Filter N/A
* Signal-to-Noise Ratio 80 dB
* Bass Boost +12 dB
Derp.
* RMS Power Output:
* RCA Inputs
* Bass Boost +12 dB
I have one of those running my 12 cvr lol.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Really? lol well that is very weird, indeed! I thought I was the only one to use a Pioneer Amp and a 12" CVR. Well it did the job pretty good for me but now i want to trade it off for a decent woofer.
Derp.
