How much db gain if adding the same sub with extra power?
Shanerator
ok, experts, please tell me once for all.. i have now 1 sub giving it 400 rms power in single sub enclosure.. I will change that to 2 subs enclosure with 2 identical subs in it and will give each one 400 rms power. So i will have 2 subs instead of 1 and all together 800 rms instead of just 400.. Is this now 6 db increase cuz i doubled the cone area and doubled the power or is just 3 db? Tnx
Basically that would be 6db. Of course you still have a ton of variables that will effect it. The box and impedance rise come to mind along with the gain from the car will be different etc.
Pioneer 80PRS
ok understand that.. just wanted to confirm this basic 3 vs 6 db thing.. so the concept is.. if you just double the power to one speaker, only 3 db increase, but if you add one speaker and give it the same power, 6 db increase in perfect conditions?
is this rule still apliable in ex. if we had 4 the same woofers (400 rms each) with total of 1600 wats rms? Is this 12 db increase in comparison with just 1 sub getting 400 rms?
Yup, you've got it right. Like ShadeTree said though, what you get in practice isn't always the same as what theory says you will get.
Builds:
ok tnx very much. Just one last question. It is the same for example with tweeters? like 1 tweeter 50 rms and then another 50 rms. Also 6 db? or no because they are on seperate sides..
Its more complicated with tweeters. Speakers (tweeters, mids, subwoofer, etc) have to be within a certain proximity of each other for their output to combine properly. The higher frequency being produced, the closer they have to be. With tweeters, since they are on opposite sides of the vehicle, they aren't going to combine perfectly. They will be louder than just one, but its not like subwoofers.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 6189 Guests (See full list)
