Help with kenwood subs please
Jkeen1978
Tune around 35 hz. I had 4 of the older models that these replaced in my blazer. 1.5 cubes per sub after displacement tuned to 35 hz should work great.
I wouldnt run those subs in a box that big. You may have problems with the subs bottoming out.
Right now I have them in a sealed box that's about 1.5 per sub. Sound OK but I was hoping to get a little more out of them by going with ported enclosure. Any recommendations would be appreciated.
depending on your install can you do an external port? if you have 1.5 sealed. people are recommending that as a ported airspace. maybe just adding a port to the outside is what is best. if not permanent at least you then have an idea of the way they will sound.
The box their in now did have a slot port in the center but Kenwood recommended a ported box from 1.75 to 2.5 and .75 to 1.5 sealed so I just capped off the port. This was the reason I was going to use this new box. at 2.15 it's well under the 2.5 Ported limit that's recommended but I never could come up with enough information to find what to tune the box to. Suggestions?
  • Who's Online   0 Members, 0 Anonymous, 6189 Guests (See full list)
