Wannabe Posted December 21, 2016 Report Posted December 21, 2016 I want to start getting stuff ordered for my upcoming build and I have no idea where to start. I was going to order my sub and amp just to have them but I feel like I should get my mids and high maybe a 4 channel amp 1st, power wire to run and to do big 3. I don't have a good resource for an enclosure but I posted a thread seeing if anyone I. My area wants to build on for me. My build is around 1750watts so I'm hoping I can squeeze by with the big 3 and a batt in the back but idk for sure. If you guys can get me going on a good plan to start getting some direction to take that would be helpful this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
reedal Posted December 21, 2016 Report Posted December 21, 2016 Sound deadener before all! If I could go back to when I bought my Tahoe, I'd do that before anything else, even though I already had most of my equipment. My recommended order of operations: deaden electrical (big three, alts if needed, batteries if needed) mids and highs (test placement to get the sound you want) sub stage SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
moh.vze.com Posted December 21, 2016 Report Posted December 21, 2016 If it's 1750 watts RMS then I'd make sure to get a new battery under the hood if you're running stock. Then I'd do the big 3. If you have an older vehicle that doesn't have an aftermarket headunit, I'd get one. I don't know much about new cars though they come with smart computers chips and crap that makes it hard to install an aftermarket one. I'd also install a stinger volt meter to see how badly your voltage drops. This will also help you decide on whether you need to add a second battery to the trunk or even get an aftermarket high output alternator. Decide on subwoofers (size, number of subs, voice coils for subs to match your amp i.e. wire it down to 1 ohm?). Decide on an amp for your subs Do research on what type of box is recommended for your subs and if you want ported, vented, or sealed. You could even have someone on the forum build one for you. Don't use prefab boxes. Decide on mid/high speakers. Decide on amp for your mids/highs (2 channel or 4 channel? if you only doing front doors with a crossover then you prob only need 2 channel). Decide on type of speaker wires, power powers (do you want oxygen free copper wires?) and RCA's. You might have to buy a hydralic crimper to crimp your ring terminals onto your power powers. Or you can solder it down with a torch (there was a meade video on how to do this). You might want to go 0 awg for your power and ground wires. 0awg vs 4 awg Knukonceptz power wire: 0 AWG power wires. You might need a lot if you're wiring a big amp and second battery in trunk: Was curious what it looks like inside the ring terminal after crimping: Here's the youtube vid of meade showing us how to solder power wires to ring terminals. I soldered a bunch of mine in 2012 and they are still intact. I later started crimping my other wires because i was too lazy to solder and one of the crimped terminals actually came loose. I recommend soldering if you have the time. You don't need a big fancy torch like meade, I used a cheap small home depot one. I normally do sound deadening last or at a later time in my builds just so I can locate all the weird rattle spots in my car and appreciate the difference in sound quality of sound deadening. The only down side is you'd have to take your doors apart many times and reapply your speakers and such. Sound deadening is expensive so I normally buy that stuff at a later time in the year once I get more money. I probably have over 200 sq/ft in my car by now. I recommend SecondSkin Audio's B-Stock supply when they have them in stock. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
twalker182 Posted December 21, 2016 Report Posted December 21, 2016 Sound deadener before all! I agree...to a point. I think sub and mids should go in first just to see where your problem areas are. 2010 Accord Sedan XS D3400R Clarion HU Sundown mids and highs Incriminator amps Incriminator Lethal Injection 12"
Wannabe Posted December 21, 2016 Author Report Posted December 21, 2016 I want a single fi Q 18" sub Running off sae-1500d amp I was going to get kicker ks door speakers and maybe run tweets of h/u? Idk how to install voltage meter or where to even find one I guess I will start with a new battery and the big 3 Then mids/highs maybe throw some deadner in the door while I'm in there. Here is the head unit I had in mind, it's says I will have to modify the fit though http://www.crutchfield.com/p_130X690BS/Pioneer-MVH-X690BS.html And I had knu power wire and solder this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
moh.vze.com Posted December 21, 2016 Report Posted December 21, 2016 I want a single fi Q 18" sub Running off sae-1500d amp I was going to get kicker ks door speakers and maybe run tweets of h/u? Idk how to install voltage meter or where to even find one I guess I will start with a new battery and the big 3 Then mids/highs maybe throw some deadner in the door while I'm in there. Here is the head unit I had in mind, it's says I will have to modify the fit though http://www.crutchfield.com/p_130X690BS/Pioneer-MVH-X690BS.html And I had knu power wire and solder I bought my Stinger Volt meter from one of the vendors on here while back for less than $20 but I don't think he's here anymore (the vendor name was Power Savings or some crap). You can just get them off SonicElectronix for now it's a bit overpriced but they've always taken care of me when my stuff broke so I recommend buying from them. http://www.sonicelectronix.com/item_46311_Stinger-SVMB.html?utm_source=google&utm_medium=cpc&utm_campaign=PLA&scid=scplp3613617&sc_intid=46311&adtype=pla&lsft=adtype%3Apla&gclid=CjwKEAiA7ejCBRDlp8uF6ezPnjoSJAAPED7MT7WbhA5qdcbtOpNzLPDYhZHwrq0pxhKjqxR_O1MyMxoCqr_w_wcB As far as choosing a headunit, I use crutch to see if it fits my car and then I go to SonicElectronix to buy for cheaper I'd get a headunit that plays CDs too! ^^ DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Wannabe Posted December 21, 2016 Author Report Posted December 21, 2016 Scratch that on kicker ks, I found fosgates for front and rear but the odd size I could only find planet audio And I don't really listen to CDs I got that one for the Bluetooth and iPhone stuff And idk anything about tweeter or how to wire a 4 channel amp, or about crossovers Does heavy bass make Bluetooth have complications? What about aux/usb connection this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
