Wannabe Posted December 22, 2016 Report Posted December 22, 2016 I already ordered a head unit, I have my door speakers picked out but i Don't know if it matters if my front doors are component set with 2 6-3/4' coaxial speakers that come with 2 tweets ( I have 2 stock tweets in front doors) and my rear speakers are a different brand but still coaxial... My question is can I run mix match brands off my 4 channel and run mix match tweets (adding 2 more on dash) off my head unit?? And my component set says there 4 ohm impendence this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
Wannabe Posted December 22, 2016 Author Report Posted December 22, 2016 I know this is probably a stupid question and I'm over thinking it but I just have never did a full install legitimately and I'm trying to figure it out by myself this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
bcbrassard Posted December 22, 2016 Report Posted December 22, 2016 Keep researching... Yes you can run tweeters off the HU but how many sets do you need? Research multiple drivers and tuning. Best sounding system can be the simplest set ups.
Wannabe Posted December 22, 2016 Author Report Posted December 22, 2016 I found all kicker door speakers with a pair of kicker tweets, I don't think I can run. The tweets off h/u cause it says it's 14watts rms http://www.crutchfield.com/p_130X690BS/Pioneer-MVH-X690BS.html?avf=Y And I guess 4 tweets would be a little too much lol Can you run 4 speakers and 2 tweets off a 4 channel amp? this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
bcbrassard Posted December 22, 2016 Report Posted December 22, 2016 Yes just depends on the speakers and what your trying to do.
oldsoundguy Posted December 22, 2016 Report Posted December 22, 2016 Your power supply (amp or deck) does not know what brand you are running and most likely doesnt care. All the amp cares about is what the OHM load is on each channel. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Wannabe Posted December 22, 2016 Author Report Posted December 22, 2016 http://www.sonicelectronix.com/item_64191_Kicker-CSS67-40CSS674.html Front doors this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
Wannabe Posted December 22, 2016 Author Report Posted December 22, 2016 http://www.sonicelectronix.com/item_64191_Kicker-CSS67-40CSS674.html Rear doors Can I run all these and 2 tweets off a 4 channel just to be loud enough for a 1500 watt sub this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
oldsoundguy Posted December 22, 2016 Report Posted December 22, 2016 You can run each component set off the front and rear channels of a 4 channel amp. So 1 6.75 and tweet with cross over off channel 1 front the other on channel 2 front then channel 3 and 4 for the rear speakers . You could add a set of tweeters to the front stage wired together with the tweet that comes with the component set but you will be splitting the power of that channel between the 6.75 woofer and the two tweeters + the crossover will take a little power. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Wannabe Posted December 22, 2016 Author Report Posted December 22, 2016 Ok cool, I might just keep the 2 tweets that come with the comp set and not do 4 tweets total. I think that will be sufficient for my system ( 1500 watts) this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
