MrSkippyJ Posted December 22, 2016 Report Share Posted December 22, 2016 If you add the battery, you will run the 1/0awg from the front battery to the back battery. You will fuse within a foot from the back battery to the fuse size recommended for 1/0, usually 300-350amp. From the back battery you then will wire to your amps. If your amps have fuses built in, you should be fine. If not, you should fuse the power wires going to the amps, again, to the recommended fuse size of that wire. You want to make sure you fuse every single power wire in the car that you add. There has been too many cases of people burning down their cars because of a improperly fused wire. just to reiterate this, every wire coming off a battery should have a fuse as close as possible to the battery. If your amps have built in fusing, you still want the power wire to the amp fused near the battery. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Wannabe Posted December 22, 2016 Author Report Share Posted December 22, 2016 I'm following you but I'm not getting the picture of the actual wiring diagram I will have going on. If I put a beefy batt under the hood and got a h/o alt do you think it would be enough for 1500-1650 rms plus whatever my 4 channel with draw And what is an average price for a singer/mech man alt? And do I have to buy these batteries on the Internet? this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs Link to comment Share on other sites More sharing options...
Wannabe Posted December 22, 2016 Author Report Share Posted December 22, 2016 I can't find the amperage on my current alternator but it shiny new so I'm thinking just 2 batteries? Or I can pull this one out sell it and just get a big batt under the hood with a new alt this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs Link to comment Share on other sites More sharing options...
06RTCharger Posted December 23, 2016 Report Share Posted December 23, 2016 3white and 3red from ur headunit, so buy 3 rca cables. Each cable has two plugs on each end, the red and white is left and right. One cable for front doors left and right. One cable for rear pillars left and right. Then one for ur sub. Link to comment Share on other sites More sharing options...
