d-nice88 Posted December 25, 2016 Report Posted December 25, 2016 I built a box that is 9 cubes gross and makes my fi bl subs sound awesome. My question is that i wana upgrade to the new sp4 or btl models and was wondering if the box i already have would be ok or would i have to rebuild?
Triticum Agricolam Posted December 26, 2016 Report Posted December 26, 2016 Its impossible to answer that question when the only thing we know is you have BL subs and the box is 9 cubes gross. What size subs are they? How many do you have? What is the net volume of the box? What is the box tuned to? How much port area does it have? What amp/s are you running? What vehicle is it in? What are your goals for the system? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
d-nice88 Posted December 26, 2016 Author Report Posted December 26, 2016 Dooh! Your right triticum my bad its 2 fi bl 15's in a slot ported box tunned to 32 hz in a 95 gmc pickup running off an audio legion 3.5k. Will be adding another 3.5 k and 2 more batts for the sub upgrade to either the sp4 or btl's. Just wana get louder. Love my bl's but i think its time for an upgrade now
ShadeTreeMechanic Posted December 26, 2016 Report Posted December 26, 2016 What are the dimensions of your port? I would guess that your existing box would work, but the port is going to be too small for the amount of power you want to run. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
d-nice88 Posted December 26, 2016 Author Report Posted December 26, 2016 Ahh i c. I forget but i built it in torres. Guess ill just have to rebuild thanks shade
