What to upgrade next... Add a sub, amp, or battery
I'm currently using a Soundqubed HDS312(1200w RMS, 2400 peak) powered by a CT Sounds 1400.1 off a XS D5100. I'm looking to add another HDS312 but I'm not sure if the one amp will be able to support the two. If not, I can get another 1400 to strap but would that require another battery in the back? Im currently riding a Genesis Coupe so there aren't any H/O Alts on the market for me. Would the single 1400.1 be enough or do I need to get the Batt and Amp first?
I would get a battery first. It should allow you to play a little louder and you might not need another sub.
Pioneer 80PRS
That 1400 puts out a lot of power. I had one and ran a soundqubed hdc 3.1 12 dual 1 ohm sub at .5 ohms and the amp took the abuse.
is your sub dual 1ohm dual 2 or dual 4?
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
It is dual 2
