X-Max Factor-Which would move more air?
Chase Wallace
Which combo would move more air and get louder? If it makes any difference lets say that both combo's are in optimal ported boxes with 4000 rms total.
Two 15" subs with 30mm X-Max and 353 square inches of surface area
or
Four 12" subs with 19mm X-Max and 453 square inches of surface area
11mm more X-max with 100 square inches less or 11mm less X-Max with 100 square inches more?
Can anyone tell me how close these two combinations are and how much more X-max it would take for the losing combination to be equal?
The two fifteens have 78 more cubic inches (23% more) of volumetric displacement.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Thanks! It seems my suspicions were correct them. If you don't mind could you show me the formula to calculate this so that I can apply it in different comparisons? My planned build is kind of strange in that I think it would be easier to fit four 12's than two 15's but I will probably try to stuff the 15's in there anyway if I can't find four 12's that would get as loud or louder for around the same price range and given the same power.
No problem.
Vd= SD ≈ xmax
vd = volumetric disp
sd ≈ cone area
xmax is stated. The only thing I did was convert it to inches, from centimeters.
LMFAO so true
:blush:
6 hours ago, hdorre said:
No problem.
Vd= SD ≈ xmax
sd ≈ cone area
So working it out...
Two 15's with 30mm  Xmax
Vd= 353 x 1.1811
Vd= 416.9283
Four 12's with 19mm Xmax
Vd= 453 x 0.748031
Vd= 338.858043
416.9283 - 338.858043 = 78.070257
Vd= 78 cubic inches more for the two 15's after Xmax is factored
I think I got it! Thanks!
Keep in mind that greater Xmax is only beneficial if you are going to be pushing that sub to a greater level of excursion.  If both subs are only going to be pushed to 17mm of excursion at the box size/tuning/input power you will be using greater Xmax potential of one sub is irrelevant.
With ported box systems the peak output is usually around tuning where cone excursion is at a minimum so greater Xmax isn't always an important factor.  Sealed box systems are a different situation.
Builds:
So if I can't compare by cone area or even total volumetric displacement then how could I figure out which combination has the potential to get the loudest? Why wouldn't I be pushing the sub to the highest level of excursion at maximum volume. I mean to me it sounds like you're saying that Xmax doesn't really make a difference when you don't have the volume all the way up. I'm not saying this is what you're actually implying but I'm saying I don't really understand.
This was all considering the subs would be in the correct box size, tuned to the recommended frequency, and given slightly more than rated power or actually a lot more. Given that all that then what better way is there to calculate which setup should be louder than using the sub's total volumetric displacement? I mean in the end aren't we basically trying to move air? If the subs were unable to reach their full Xmax then wouldn't that mean they were in the wrong box, tuned to the wrong frequency, or under powered? I just don't understand why a sub with 30mm Xmax rated at 1500 RMS and given 2300 RMS wouldn't be able to reach it's full Xmax and move its full volumetric displacement potential.
If I'm just totally not getting it then seriously please teach me more before I waste a huge amount of money "to me".
32 minutes ago, Skullz said:
Want more air movement?
Controlling cabin gain will get you farther along than xmax.
I'm wanting to figure out which subs or combination of subs have the potential to get the loudest. Surely there is some decent way to compare one sub to another without just looking at brand names or testing every one in every vehicle...
Volumetric displacement is directly related to output for sealed boxes but for ported boxes it isn't.  The reason for this is around the tuning frequency of the box ALL the output is coming out the port and nearly NONE is coming from the cone. At this point there is very little cone movement, so Xmax is irrelevant. Many subs these days have so much excursion capacity that they will almost never be pushed to their mechanical limit. Mechanical isn't the only limit subs have though. They are also limited by thermal capacity.  In a ported box at some frequencies (like around tuning) you will be limited by thermal capacity before mechanical. Other frequencies you will be limited by mechanical capacity, but with ported boxes that's probably not where peak output will be.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1056 Guests (See full list)
