Soundqubed 4500.1 keeps going into protection
shepherd92683
I will start by saying I haven't changed anything with my system since I reinstalled the amp over a year ago when I came back from being repaired. It worked great for the last 11ish months... Now what happens is randomly it will go into protection. Low volume, or high. I disconnected the subs, still did it. I shut off the sub output on the head unit, same thing. The last thing I've tried is disconnecting the rca's. It hasn't done it yet, but I just tried today. If it is the rca's that are bad, how  will I know if it's the cables, the amp, or the head unit?
2017 Honda Accord Touring
Build coming soon
Disconnect current RCAs and amp doesn't work = amp
Disconnect current RCAs and amp works = HU or current rca
If the amp works when you take out the RCAs then you'll have to get new ones to see if it was the RCAs or HU. New RCAs work and amp plays then you know it was just the RCAs. If the new ones don't work then it would be the HU.
Before you do any of that, check your grounds. You know things come loose.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
Second Skin
^^^ Build ^^^
Thanks. But before I go buy a new set of rca's, I guess I could  check them with a volt meter. And the same with my h/u.
Build coming soon
i didn't even think about it, not sure why. Let us know what the issue is.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
Second Skin
^^^ Build ^^^
check for bad caps inside your amp. I have a amp now doing the same thing it had 6 bad mosfets and 2 popped caps, its a bs sound storm amp i got for 5.00
https://www.youtube.com/channel/UCWd1ShRnPbDG9ppgJKpumdA <---- show some love to my channel
Alpine MRH-F255 (old school), sub channel not used
Skar audio VX35-ST tweets in front  (invest in them they are worth it)
kicker zr120- nice underrated amp
Powerbass s1204 subwoofer in a 1.75 custom slot ported enclosure tuned to 30hz
Front doors Prv 6mb200s 8ohm
Alpine type-e 5.25 in dash took a shave and a hair cut.....- not in use
Rear doors alpine 6.5's model/series unknown but they are loud as hell
Factory alt
3.5 farad cap, does the job for now.
Deck is a pioneer mixtrax 700bt model
And my baby my Pioneer EQ-6500 i got for 10.00
Back-up amps- Ma Audio 598i, kicker zr120, my highly under rated JBL LC-A502 1xx watt amp...
On the side- Quantum tweets not yet installed
  • Who's Online   0 Members, 0 Anonymous, 1683 Guests (See full list)
